Arcgis Pro Symbology Size Error
1286
05-09-2020 07:12 AM
BurakOğlakcı
Hi everyone,
I can't change the dimensions of vector data in arcgis pro. When I want to hatch my area, I encounter a problem like the one in the image.
Error screeenshotThe same problems happen when creating labels
Thanks for your help.
Robert_LeClair
Esri Esteemed Contributor
Burak - it seems you have a Reference Scale set for a Small Scale (i.e. 1:1,000,000 for example) and then zoomed into 1:50,000.  The result is what you're seeing with your polygon symbology.  To remove this, right click on the Map name in the Contents Pane and select "Clear Reference Scale" - what is the result?
BurakOğlakcı
Dear Robert, thank you so much your reply. I will try your suggestion.
