Hi everyone,
I have a quite strange Problem in ArcGIS Pro when working with reports.
In general, I create a rectangle polygon text field an include a dynamic text to show some field values. I use the polygon text field because I can define the height and the width. This is important to wrap the field values across several lines.
Now the problem. Sometimes / often when I create a new a rectangle text polygon for my dynamic field value and I try to change the height of the polygon the width is scaling proportionally like it is lock, but you cannot lock the proportion for a polygon text field in the report. The problem is the same when I copy a text polygon which is "not" locked.
Maybe somebody could help me out 😉
Thanks René
