ArcGIS Pro Report Expression Not Reading Joined Field Correctly
140
07-07-2026 08:55 AM
dnieves
Hello, I am creating a report in ArcGIS Pro and using an Arcade expression to group two field values into a single label. The field I am referencing comes from a spatial join.
I have also tried other alternatives such as using what if statements.
The expression returns nothing. So how should joined fields be referenced inside report expressions? Do joined fields need a specific syntax in Arcade when used in a report?
Thank you!
Robert_LeClair
Esri Esteemed Contributor
Joined fields should be referenced in Arcade using bracket notation and the fully qualified table.field name:
var a = $feature["JoinTableName.FieldA"]
var b = $feature["JoinTableName.FieldB"]
return a + " / " + b
This is the documented syntax for joined fields in Arcade: $feature['tablename.fieldname'] (same Arcade field access rules apply).
If your expression returns nothing, the most common causes are:
  • You used $feature.JoinTableName.FieldA (dot syntax won’t work for joined fields).
  • The join table name in the layer is not what you think (it may be an alias or auto-renamed). Use the exact qualified name shown in the layer’s attribute table fields list.
  • The “joined” values aren’t actually present (no match in the join), so the joined field is null.
Also, if you’re using a temporary/in-memory join, consider writing the join results to a new dataset (for example, run Spatial Join to create an output feature class) so the report is reading physical fields rather than a live join.
