ArcGIS Pro Reconcile and Post
3998
10-13-2014 06:01 PM
BenVan_Kesteren1
Hi All,
I am just dipping my toe into the waters to see if ArcGIS Pro will be useful for my workflows, and I have hit a wall already.
Has anyone worked out how to use versioning in Pro? In ArcDesktop we do our edits, press save edits, then reconcile then post, worked fine. but with Pro there is no such buttons. I have added the data via a database connection which has my version specified, so it should be obvious.
Anyone been able to get this working?
Cheers
Ben
Nathan Duncan
Robert_LeClair
Esri Esteemed Contributor
Nathan - there is a Reconcile Versions Geoprocessing tool in ArcGIS Pro that has a "post versions after reconcile" parameter you can check to post your edits to the parent version.  You are correct that in ArcGIS Pro, the Versioning Toolbar is not there.
Hope this helps.
Regards,
Robert LeClairEsri-Denver
larryzhang
ben,
pls check the help for Pro 1 (Prorelease):
Reconcile Versions—Data Management toolbox | ArcGIS for Professionals
