ArcGIS Pro "Project not found" error, missing .aprx and toolbox.
25581
36
04-01-2020 11:47 AM
DM_GISServices
Hello all,
I had a project I was working on in ArcGIS Pro earlier today in which I had a toolbox with a few models, a script, and FME tools. A few minutes after having closed out Pro, I re-opened it and tried to open the project from the "Recent Projects" link. I then got a "Project not found" error with the message (attachment included), "Sorry, we couldn't find your project. Do you want to remove the project shortcut from your list of recent projects?" Instead of removing it I navigated to the project in Windows Explorer and found the .aprx to be missing along with the toolbox in which I had been doing work. I had searched about this problem a year or two ago (a coworker experienced this problem) and was able to find that a couple people had run into this before, but searching now seems to bring no results. I wanted to ask you all - have you had this problem of ArcGIS Pro disappearing projects before and were you able to recover your projects without restoring previous versions of the project's parent folder? I have spent a long time working on this project and would like to avoid having to start even from a recovery point.
-Max
EDIT: Please post here if you have had this problem too! There does not seem to be a solution at this point, but the more people that can share their experiences having this problem the more likely we are to be able to find out where this problem is stemming.
Tags (1)
WA_Holmes
This has happened to me a couple of times and I had to get my IT team to restore the files from backup.  I'd forgotten about it until a less experienced colleague had the same thing happen today and now I'm worried given I've just migrated everyone else from ArcMap to Pro.
I don't know the exact cause but my gut feel is that at some point while a session was open, my computer lost connection to the network/VPN and although my computer recovered, ArcGIS Pro couldn't.  It says it can't save, not even save as, so you quit and lose everything.
I possibly found a least worst scenario by force quitting ArcGIS Pro which means losing everything since the last save, but it didn't give Pro the opportunity to delete everything.  I wouldn't put 100% faith in doing this but it seemed to work the last time it happened to me.
We're using version 3.1
KellyPilarski
We had the same situation today. The project errored on saving and closed when we went to go back the .aprx file was missing. Searched all drives on computer and server it is no longer there. All of the ancillary folders do exist, the database , Index and .backups all there, but the actual project is now gone.
Margaret_M_Maher
Regarding this issue of losing your ArcGIS Pro project and having the .aprx file disappear from the computer, if you have a Maintenance contract with Esri for software, please open a Technical Support case by calling 888-377-4575 and press 2 for Technical Support. Press 0 if you want to speak to a Receptionist, otherwise follow the phone tree.
If you do NOT have a Maintenance agreement go to https://support.esri.com/en-us/contact scroll down on the page and click "Report a bug".
PeterForister
Where are my projects going???
I've lost two significant project files in this way in the last week, and four overall in the past year. The .aprx file simply disappears from the project folder after closing ArcGIS. When reopening, the "project not found" message is displayed and the .aprx file is no longer in the project folder on my drive, despite not being moved or touched in any way between working sessions.
This is incredibly frustrating and demoralizing. The backup folders are empty, and the logs don't seem to have any useful info. I got smart and started manually exporting entire project packages every 2-3 days plus my normal backups, but the volume of work that occurs between those backup periods in non-trivial and this issue often wipes 5-10 hours of work.
Has any progress been made to diagnose or fix this issue from Esri? There's little useful troubleshooting information in this thread. At very least I'd like to know how to avoid it, whether that's structuring my project in a certain way or avoiding a certain shutdown sequence. At this point, the only safeguard I could come up with is backing up the entire project/data folder every hour - but that doesn't solve this issue.
LisaCasey
I have had his same issue - On my end I have noticed that this occurs since upgrading to Windows 11, and if I leave a project idle.
I was running a cache over the weekend. The cache finished building, (18+ hours) but I could not save the project file. I could not save even as a new project and when I closed the project file had erased. Also, no backup. I noticed that before closing, the project said "back up in progress". I suspect there is an issue with the operating system since, at least for me, this issue did not occur with windows 10.
One bright spot --- I was able to restore my .aprx file using the "previous versions" tab in windows file explorer:
ARM
Unfortunately, this issue still hasn’t been solved, and I’ve now lost several weeks of work because of it. It has affected three ArcGIS projects and folders that were saved locally and hadn’t been moved or opened since before Christmas.
I’ve searched everywhere for these files with no luck. I even tried recovery software, which showed that several items had been removed (not for me, I'm sure!). Unfortunately, none of the recovered files were usable to restore the projects or their geodatabases. What’s odd is that all these projects were stored in the same local folder and are from similar dates, yet nother project I had been working on around the same time is unaffected, but instead it was saved in the local ArcGIS folder. There has to be an explanation.
This has happened to me before, but at the time, I thought I might have made a mistake. Thankfully, I had saved a version of that project in the cloud, so I was able to recover most of it. Based on my experience, cloud storage and ArcGIS folders seem to not be affected, though I can’t understand why.
Is there any solution to this that I might have missed? TY!
MargaretMaher
Hello,
I am so sorry you are still encountering this issue. I've kept tabs on this issue, but unfortunately we have not yet been able to capture a reproducible case of the issue, even though some Support analysts and Developers have experienced this error.
I have attached the text from one of our internal Knowledge articles that discusses what we have learned about the issue. I hope the information included may be helpful in rescuing your projects.
I do not think the problem is associated entirely with the Windows 11 operating system since this was occurring before Win 11 was released.
Even if you don't have a maintenance agreement with Esri for the software, I'd encourage you to access this link to "Report a bug" to Esri Support. Even if we cannot resolve the issue for you, we can compile information and may find additional clues that will allow us to resolve the issue. The information you provide is important. As a Support Analyst for 24 years, I can say beyond a shadow of a doubt that "Tech Support is a team sport" and we value your input.
Margaret Maher
Esri Support Services
