ArcGIS Pro provide user feedback when select attributes change. Can this be done using attribute assistant?
945
08-26-2021 01:40 PM
LyonMNGIS
After a user edits an attribute, I would like to find a way for ArcGIS Pro to display a popup reminding users that they may want to consider updating a couple related attributes that may or may not need to be changed.
A few use cases:
If a first name on a layer is modified then ArcGIS should remind the user that they may want to consider changing the last name.
If the address range changes on the right side of the road then ArcGIS should display the address range on the left side of the road so that users can modify the left address range as well.
Is there any way of doing this by using the attribute assistant?
