Calculating Routes from the same Starting Point to different Locations
1036
08-26-2021 12:30 AM
Labels (2)
SebastianNiesner
Hi Esri Community!
Currently I am working on a location analysis for one of our facilities.
My task is to do an analysis, where the distances from our facility to our customers for the last two years are calculated.
Is it possible to calculate those routes all from the same starting point?
Thanks in advance
Sebastian
DavidPike
MVP Notable Contributor
You could certainly iterate the route creation, but you'd be better off using Closet Facility (just use the 1 facility/origin). https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/closest-facility-analysis-layer.htm
If you just need the distance/time, then OD Cost Matrix would be ideal https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/od-cost-matrix-analysis-layer.htm
DavidPike
