Arcgis Pro - OVERWRITE existing Standalone Service with python
1622
07-15-2020 08:30 AM
jonathanharte
arcgis pros1
Arcgis Pro - OVERWRITE existing Standalone Service using python The current process in Arcgis Pro (Manual Only)
I have and existing service published to standalone Arcgis server 10.6 that is cached, and I want to automate an Overwrite process that retains the cache but replaces the base data I use for popups.  I've been doing this for years and its simple in arcmap ... Its also simple in Arcgis Pro if I right click on the service and use the Overwrite function - but I need to automate in notebook this but there does not appear to be anything in python to do this .. Or have I missed a  process?
I have followed some threads with various leads .. but so far I have been unsuccessful...   I can create a sddraft and an sd for the service with the new content - but when I try UpLoadServiceDefniition .. it fails with service already exists but I cannot seem to find any switch to allow it overwrite ?
In the future I will be doing this with hosted features on my portal - but for the moment this is not an option for me.
Any pointers would be hugely helpful please...  my efforts so far have not been successful.
Regards
Paulg
KoryKramer
Esri Esteemed Contributor
Have you read through https://community.esri.com/thread/216491-automate-overwrite-web-layer-feature-class and tried the example(s) provided?
Arne_Gelfert
Following the general 3-step process I've seen in so many ESRI examples - Draft-Stage-Upload, the overwriting puzzled me until I added the line high lighted below:
# Create MapImageSharingDraft and set service properties
sharing_draft = m.getWebLayerSharingDraft("FEDERATED_SERVER", "MAP_IMAGE", service)
#The following line governs whether the new draft is used to overwrite the existing services
sharing_draft.overwriteExistingService = True
sharing_draft.exportToSDDraft(sddraft_output_filename)
# Stage Service
arcpy.StageService_server(sddraft_output_filename, sd_output_filename)
# Share to portal
arcpy.UploadServiceDefinition_server(inSdFile, inServer, inServiceName,inCluster, inFolderType, inFolder, inStartup, inOverride, inMyContents, inPublic, ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The exact details may be different in your environment.That's why I've stripped it down.
