ArcGIS Pro on virtual machine problems find path
530
06-06-2025 06:20 AM
TimSemmelhaack
I've installed ArcGIS Pro 3.51 on a virtual machine Hyper V Windows 11
When I run a notebook I've a problem to access files on the host computer
Path(path_c, routes)
WindowsPath('//tsclient/C/ArcgisPro_lokal/projekte/umlauf_ivu_vrp/input_vrp/20250606_2025-07-01_amm_sued_vergabe_routes.csv')
Path(path_c, routes).exists()
True
arcpy.Exists(Path(path_c, routes))
False
In my opinion Path().exists() and arcpy.Exists() should return the same result.
Also other arcy modules can't locate the file. Any idea?
Tim
MarcoBoeringa
What happens if you make the path a raw string? So:
arcpy.Exists(r"<YOUR_PATH>")
