ArcGIS Pro not showing created/edited features until after the edits are saved and the map is refreshed?
2648
7
04-02-2020 10:41 AM
by Anonymous User
Not applicable
Here is a gif illustrating the problem:
20 minutes ago, the points I created stayed regardless of if I had saved edits or not.
This is the second time today that I have had this issue. The first time, I solved the issue by recreating the project file entirely, however that is much to tedious to have to do again. I would like to figure out what is causing this issue. There are no definition queries set that would cause this behavior either. This issue also occurs when changing attributes that control symbology. See below:
Previously, the line color changed instantly. No need to save and refresh the map. I really need to find a solution to this problem because it is crippling my productivity.
Thank you!
AdamHart2
I have the same problem. I create a feature, it disappears until I save edits and refresh. I change the attribute of a feature, the symbology doesn't refresh (unless I save and refresh the map). Unbelievable.
RhondaPhillips
Having the same problem and even adding duplicate address points because the first does not show up.
Found this about feature cache settings maybe it will help.
https://support.esri.com/en-us/knowledge-base/features-are-sometimes-not-displayed-or-no-longer-sele...
BrianShepard
@AdamHart2 @RhondaPhillips Did you find any resolution to this?
This same issue happened to me - I'd edit vertices on a line and the line doesn't move; I'd move a point and it'd stay in the same location; I'd add a point and it doesn't show up. When I save edits and refresh the map they display in the correct location, but in the case of a line vertex edit, the old location would still show as selected even though the line now displays in a different location. I tried clearing the map cache and then created a new project, but I'm still having this issue. It makes editing really difficult.
BrianShepard
Esri Support was able to resolve the issue for me. I'll clarify that it was happening with multiple feature classes in a file geodatabase.
Steps for the resolution on ArcGIS Pro 3.4.3 (at least for me):
  1. In ArcGIS Pro, Open Display Settings (Project > Options > Display)
  2. Change Rendering engine from DirectX12 to DirectX11
  3. Clear Local cache
  4. Check "Clear cache each time application closes"
  5. Click OK - ArcGIS Pro automatically closes and reopens the project
  6. Close ArcGIS Pro (no other instance of ArcGIS Pro should be open)
  7. Search Windows for "Graphics Settings"
  8. Under "Choose an app to set preference", click Browse
  9. Navigate to the ArcGISPro.exe file (C:\Program Files\ArcGIS\bin\ArcGISPro.exe)
  10. Set Graphics preference to High Performance (GPU: AMD Radeon Pro W550 in my case)
  11. Save
  12. Reopen the ArcGIS Pro Project
GregoryAntonini
Anyone have a 2026 update on this? We have teammates on both 3.3 and 3.7 that are experiencing the issue, happening most in the Parcel Fabric. Seems to happen at random - and either editing geometry or attributes or even delete can cause it. I tried the 12-step process previously mentioned (except for switching DirectX version) and that didn't make a difference. I can't imagine the DirectX version is the problem here as 3.3 defaults to 11 and 3.7 defaults to 12.
George_Thompson
Esri Notable Contributor
If you are using versioned data in the Parcel Fabric, you may need to "Refresh" the version (https://doc.esri.com/en/arcgis-pro/latest/help/data/geodatabases/overview/versioning-tab.html#970) as Pro caches the data when you start an editing session or connect to a version. This will pick up any updates in the data.
Here is a blog talking about some of the changes implemented at Pro 3.4: https://www.esri.com/arcgis-blog/products/arcgis-pro/data-management/versioning-tab-updates-in-arcgi...
--- George T.
BrianShepard
FWIW, the steps I previously posted did resolve the issues, but not long term. The issue has come back several times, but only for one Pro project in particular. It's still an issue even after getting a new computer with a new installation of ArcGIS Pro and a different video card. It was resolved temporarily using those steps on the new computer, but setting Pro to use my Nvidia card exclusively in Graphics Settings has caused other issues including instability/reboots/graphics errors on a new Dell Pro Max laptop. Setting that back to Windows controlled resolved those issues. Recreating the Pro project from scratch using the layers required for editing works fine initially, but having done that 3 or 4 times, it always ends up with my edits not being shown without saving and refreshing. I'm not using Parcel Fabric and haven't been able to figure out a long-term resolution to this.
