ArcGIS Pro & MXD
13533
12-05-2014 10:43 AM
RenatoSalvaleon
What happened to the map document or mxd?
JoshuaBixby
MVP Esteemed Contributor
Map documents (mxd) are part of ArcGIS Desktop, not ArcGIS Pro.  ArcGIS Pro is organized differently and has Project files (aprx), similar to the old ArcView Project files (apr).
Once you create a new ArcGIS Pro project, you can import MXDs as maps within the project.
JoshuaBixby
JessicaKirby2
Seems like a silly question but is it possible to open an arcpro project within desktop?  or are you committed to pro once you import?
JoshuaBixby
There is no way to import APRX files into ArcMap.
JessicaKirby2
I didn't think so, thanks for confirming
khairulamri
Document file such as .mxd, .sxd, *.3dd cannot be used as usual. you have to import those file in ArcGIS Pro project. create or open your ArcGIS Pro Project (.aprx) then import your map document (.mxd).
this is the url link for common question regarding ArcGIS Pro : What's Coming in ArcGIS | Common Questions
