ArcGIS Pro Modelbuilder - How to specify which map with the "add to display" option
796
04-01-2022 12:56 PM
Labels (2)
NMcIntyre
I'm utilizing a model to update feature layers in AGOL.
The model I have used follows this blog post: https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/publish-and-overwrite-web-layers-in-mod...
I need to go this route, and I understand other options exist.
The problem:
I have a layer which first needs to be copied out of the master geodatabase and joined to another table before this model runs. With this model, each feature class needs to have it's own map (there are multiple feature classes and maps within this ArcGIS Pro project). When I run a model to automate the Copy & Join, the feature class is removed from the map I placed it in. I can automatically add this feature class by clicking the "add to display" function in the model. However, this project has multiple maps within it's project.
How do I specify which Map the "add to display" function adds to?
