ArcGIS Pro Model Builder Model
2083
03-02-2021 07:31 PM
Labels (2)
KBNehru
I have a model that creates two buffers (100m and 450m). Each buffer zone intersects a Zone (polygon Feature Class) and summarises results per zone into two tables.
The second model that deletes buffers and summary tables
When I run first model, how to run second model first followed by first model.  I have raised it with ESRI Support. I just got only generic help.
DavidPike
MVP Notable Contributor
I'm not entirely sure what you mean, although:
Add a submodel to a model—ArcGIS Pro | Documentation
You may also be best to just write your data to a memory workspace rather than create stuff you need a second model to then delete:
Write geoprocessing output to memory—ArcGIS Pro | Documentation
Or... Python!
JayJohnsonWashoeCounty
To re-state the problem, you want to delete the buffers and summary tables (Model 2), then create the buffers (Model 1).
Easiest thing might be to put all this processing into a single model.  That way you can make last process in Model 2 a precondition of the first process in Model 1.  That would force operations to happen in the desired order.
Jay
Washoe County GIS
KBNehru
I am failing to understand where to call second prior to running first model.
A couple of different ways you can approach this.
1)  Don't break it into two models like that.  There is no real reason to have two separate models.  Take the operations you are currently running in model 2 and copy them directly into model 1 so that EVERYHTING is happening within a single model.  Then make all that stuff you just copied in a precondition.  That would force it to run first WITHIN that single model.
2) Alternatively, call model 2 as a sub-model from within model 1.  See this link for how to do that:  https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/modelbuilder/add-a-submodel-to-...
Jay
Washoe County GIS
