I am using the "Merge divided roads tool" in arcgis pro but the output does not come as desired.
Where the road makes a 90degree turn, the ouput feature does not have a 90degree turn but rather a curved turn.
Refer the picture. The blue line is the input feature and red is the output feature.
Is there a way that I can get a line through the center of the parallel blue lines ?
Thank you
Is everything projected OK?
Have you tried Integrate Integrate (Data Management)—ArcGIS Pro | Documentation
(beware this modifies input data - make a copy of it or run in edit mode)
or possibly create a polygon from the lines and run polygon to centreline How To: Create centerlines from polygons in ArcGIS Pro (esri.com)
