ARCGIS pro map to kml
6344
7
07-08-2021 09:51 AM
JohnSpears2009
I am using the map to .kml geoprocessing tool. The .kml is created but is not showing the title I have selected in the pop up. I can change it in ARC but it will not change in the .kml.
I know I'm overlooking something. What do I need to do the display the title of the attribute in the drop down in Google Earth?
Tags (3)
CarlMorrison
Check out https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/layer-to-kml.htm which should help, also if you label the feature in ArcGIS Pro, the kml will carry that label as the name for the feature.
However, one thing to note is if using the kml in GE, only point features will show a "Placemark" label.
Another trick is to add a field titled FolderPath to your feature class and populate it with the folder structure you would like to see in the kml, check this link https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/kml-conversion.htm for help with this and other tips.
ABishop
Maybe once you change it in ArcMap, export it again to another kml to keep the changes then try again in Google Earth?
Amanda Bishop, GISP
CarlMorrison
JohnSpears2009
That was it.
Thank you for the information.
JohnSpears2009
Thank you for the advise.
I forgot to mention it is in ArcGIS Pro, not that it would affect the steps that you have presented.
Unfortunately I get that same result.
ABishop
@JohnSpears2009
Would you mind sharing your .kml file with me?  Also, what version of ArcGIS Pro are you using?
Amanda Bishop, GISP
JohnSpears2009
Got it resolved, thank you for you response!
SilentCartographer
Hey John,
What was your final solution for this. I am facing the same issue. Cheers.
