ArcGIS Pro map question
2263
5
05-20-2020 04:48 PM
DEAF_PROBERT_68
Honored Contributor
I don't know if this is a simple question to ask ....
So my question here is....how do I add a map that is already set it up and it is in another folder...
So when you start a new project and you need to get that already map and add to the project
For example, you had the previous projected ( A) already created  but it is in a different folder. So when you are done with project (A) and you start a new project (B) .  You had the map from the project (A) and you are in project (B) already.
How do you I grab that map from the project (A) to the project (B).
Is there a work around to do that ?
Using ArcGIS Pro 2.5.
DanPatterson
MVP Esteemed Contributor
You can connect to a folder that contains your other data
Connect to a folder—ArcGIS Pro | Documentation
and add a database in that folder
Connect to a database—ArcGIS Pro | Documentation
Is that what you mean Robert Pollock
... sort of retired...
DEAF_PROBERT_68
Honored Contributor
Yes I did that just before I post this BUT the map does not show up ...I was wonder if it is because of the previous version is prevent me to see it ?
The only way around I can do is open another ArcGISPro  project A and copy the map from Project A and then paste onto ArcGIS Pro Project (B) .
Hmmmm............
TimOrmsby
Hi Robert,
You can also save your map from Project A as a map file (.mapx). That saves all the map properties. In Project B, add the map file to the project (on the Insert tab click Import Map and browse to it.) The map and all its layers, layer symbology, etc. will show up, exactly as in Project A... as long as the layer data sources are still accessible, which they should be.
DEAF_PROBERT_68
Honored Contributor
That should work !  I tried using import but now you have told me there is another step to do that...
Thank you
Robert_LeClair
Esri Esteemed Contributor
Robert - map views (2D/3D) are stored in the *.aprx project structure.  The only way to get a map from Project A to Project B is the copy/paste workflow you described.  You may read more about it here.  A second workflow is to create a map package of the map view but this workflow creates a duplicate of your data sources.  Perhaps not the workflow you'd like to do in this case.
