ArcGIS Pro Legend Bug - Items disappear when second data frame is added.
25054
38
12-06-2017 02:25 AM
JoeNunn
I have a Layout set up with a legend with many features linked to the Main data frame, that i spent a lot of time setting up.  I then added a second data frame to use as an overview map.  The legend still says it is pointing at the main data frame but it seems to have lost all items in the legend layers list.  The Legend is now empty (it is not like they have been unticked - there are no items there).
Is there a way of adding items back into the legend?
See screenshot of legend with no items but still pointing to main data frame?
Nothing under legend in TOC
Legend Properties pointing to main data frame. Legend Items Greyed out.
TomBole
Tom Colson - thanks for the video and especially for the text commentary. There are a number of things going on here. I'll use the timestamp to organize the issues below.
@ 1:30 – “Why are there no legend items when I inserted the legend?”
This is expected behavior. Though we may need to review for a better user experience.
When you changed the basemap the new basemap gets selected. The layout read this as the selected layer.  When layers are selected (in an Active Layout) and you insert a legend only the selected layers are included in the new legend. In this case a basemap layer is selected which does not have any valid legend so the legend is blank.
If you had added a feature layer (ex: state boundary) to the map and then added a legend the legend would only show the state boundary – i.e. the selected layer map layer in the Contents pane (Layout view active). We do this to support the use case where you only want to create a legend for specific layers in your map. You do this by selecting layers (in the Active layout view Content pane). Unfortunately, a side effect of this is that when you add a new layer it is the selected layer.
Pro Tip: Before adding a legend select the Map Frame it belongs to in the Contents pane, then insert the legend.  This should avoid having any layers selected.
As the video shows @ 3:05 by switching the source map frame back and forth you can "refresh" the legend.
@ 3:19 - Legend goes blank after toggling layer visibility
Not able to reproduce. May be related to Bug #1
So far, I have not been able to reproduce this, but I suspect that there is a refresh issue due to the legend getting out of sync with the map. I believe this happens once the order in the Contents pane for legend and map frames change. See Bug #1.
@ 5:13 - Move legend after adding a new map frame (different map) and then changing the source map a number of times results in invalid legend items.
I CAN reproduce this. BUG #1.
This may be related to another BUG where the legend items or the map frame/map items disappear after reordering the Legend or Map Frame in the Contents Pane. We are currently looking into this.
@ 6:50 “Turn off one legend item, note how all are removed?”
It think that this is likely another manifestation of the previous “reorder” bug above. The element is “out-of sync” with the map.
@8:11“Change maps in the map frame, now my extent is gone?”
I CAN reproduce this. BUG #2.
A re-sourced map frame should zoom to the full custom extent of the new source map.  The zoom is not occurring. We will look into this.
@10:54 “remove 2nd frame, turn legend off, then on….legend gone!”
I CAN reproduce this. Most likely due to BUG #1.
Looks like the legend is getting out of sync when the source map of the additional map frame is being switched back and forth (and at one point includes the map that the legend points to). I believe this issue is another symptom of the core issue that is causing the other legend bugs.
A lot going on here.  I did not go through every item in this thread. I would encourage anyone reading this that feel they have an issue that is different than the one's Tom has shown in his video and that I have addressed above to take this this issue to technical support. They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
XanderBakker
Esri Esteemed Contributor
Can you include screenshots of how your map looks like before and after inserting the new map frame? I just did a test and could not reproduce the problem. The legend keeps pointing to the correct map and the items still show.
JoeNunn
Hi Xander - before the legend had lots of items in it visible. When i added a second data frame the legend was still there but completely empty - no items were visible in the TOC or on the layout.  It is worth adding I had map series enabled.  Not sure if a screenshot will help on that? I currently don't want to recreate it if possible, and lose the legend again!   In the end i had to rebuild the legend after adding both data frames in.
I find arc pro has lots of features i want but i don't find it that conducive to rapid working.  Also the  projects add a level of complexity to the system.  Maybe I will start to get used to it.....  Its a shame because certain things such as how the legend works is loads better.  In Arcmap i never got word wrapping to work (words disappeared when that was turned on).
thanks
joe
KoryKramer
Esri Community Moderator
Joe, I also can't reproduce this.  To answer your question: Is there a way of adding items back into the legend?
Yes, you can just drag and drop layers from the map frame into the legend.
Nothing in legend:
Drag/drop:
I've searched our support system and I haven't found a description of this.  I'll try a little bit more and post back here if I find something.  Otherwise, please keep an eye out for reproducible steps and report to technical support to get a bug logged.
Thank you!
HughRound1
We have the same issue, continually. Often some layers stay in the legend, but a majority disappear. In addition, legends with more than a few layers in them are prohibitively slow to refresh. For common background layers, we have had to resort to using images of the legend to avoid these two issues.
JoeNunn
thanks - im not the only one then!
XanderBakker
I'm gonna tag someone that knows a lot of ArcGIS Pro: Kory Kramer .  Kory, have you seen this behavior before, can you reproduce this?
StephenRuhl1
We are seeing this behavior as well.  Has anyone found a solution?
MichaelJohansson4
Having this issue as well. Re-adding the legend doesn't do anything and click and drag to re-adding the items doesn't work. The legend is simply stuck with nothing in it.
EDIT:
Got it working by removing the "stuck" legend. Then DELETING the map frame that it didn't want to show anything from. Then undoing the delete (Ctrl+Z). Then re-adding the legend now all of a sudden has all of the legend items!
JoeNunn
Thanks it is not just me then!  As a result of these bugs I am still not committing to using Pro for project work and map production just yet.
