ArcGIS Pro Interface
1746
02-15-2017 07:34 AM
RichardBeier
Can you change the color scheme from light to dark?  In AutoCAD, you can do this in Options-Window Elements-Color scheme.
JoshuaBixby
MVP Esteemed Contributor
Application options, there are two:  Light and Dark.
RichardBeier
There is no "Personalize" selection within General under the Application group.  I am running ArcGIS Pro 1.2 and navigating to the PROJECT tab - Options - General.  Where is the Theme drop-down menu?  There is no "Personalize" option there.
JoshuaBixby
Personalizing the application theme was introduced in ArcGIS Pro 1.4 (see What's new in ArcGIS Pro 1.4).  Seeing that ArcGIS 1.2 is being retired this September, it might be a good time to consider upgrading to 1.4.
