ArcGIS Pro installation
7550
8
01-23-2015 05:51 AM
TomKawa
I'm planning to start evaluating ArcGIS Pro.  Does anyone know if there is a way of having both 10.2.2 and Pro on one system?
Tom
TimWitt2
Tom,
ArcGIS Pro runs independently from ArcGIS Desktop, you don't need to worry about installing both. I have both installed at the moment.
Tim
TimWitt2
Tom,
Tim
ChristopherMoore
You can install them both (10.X and Pro) on the same machine, there are no conflicts between the two.
- Chris
AsrujitSengupta
Yes, you can have ArcGIS Desktop 10.2.2 and ArcGIS Pro on the same machine. It will work fine.
JohnSobetzer
Honored Contributor
They can be installed and run side by side.  They are independent programs.
TomKawa
Thanks guys!
TimWitt2
Don't forget to mark the correct answer and in this case I would give everybody a helpful
TomKawa
Thanks Witt...as you see that was my first topic ever...
Tom
TimWitt2
Welcome to the forums!
Just as a reminder for next time, you can put tags to your question and also put it in a fitting space.
Tim
