ArcGIS Pro Export Layout Top Margin Disappears
1663
08-09-2022 06:48 AM
ChristinaNeal
Hello,
I have a map series layout set up in ArcGIS Pro 2.9.2. My page is set up to use a standard letter size paper 8.5 x 11. I set a guide in my layout to have about a 1/2 inch margin from all four sides. When I export my layout to PDF, the top margin disappears and the text aligns to the very top of the page.
I attempted to lower the margin to 1 inch but the same thing happens. I also attempted to add a new line return in my text box but that did not make a difference either. What could be causing the top margin to disappear during export?
Layout properties showing page size.
Guides in layout view showing top margin.
PDF Export - top margin removed
AubriOtis
Do you have clip to graphics extent check on in your export? That clips to the graphic boundary and removes any margins. I can't think of any other reason this would be happening.
Cheers,
Aubri
AubriOtis
Cheers,
Aubri
ChristinaNeal
That was exactly the cause. I must have accidentally selected that and did not notice. Thank you for your time!
