ArcGIS Pro: Error writing installation information to hard disk.
1448
03-06-2023 06:57 AM
sigarwang
"ArcGIS Pro installation program information
Error writing installation information to hard disk. Make sure you have enough hard disk space available, and then click Retry or Cancel to end the installation."
I'm sure I have enough hard drive space, but the C drive is only 7g.Can anyone help?
DanPatterson
MVP Esteemed Contributor
Test your computers ability to run Pro first.  See the link
Verify your computer's ability to run ArcGIS Pro on
ArcGIS Pro 3.1 system requirements—ArcGIS Pro | Documentation
You can determine the local where you want Pro to install if it is for a single user install.
... sort of retired...
sigarwang
Tests showed that my computer was configured well enough to run arcgis, but it still showed a lack of disk space, and I wondered if it had only checked the C drive during installation.Snipaste_2023-05-05_15-31-59.jpg
DanPatterson
it only checks the disk that Pro is installed on, so you will have to clean up any other disk yourself, especially if you use it for temp files
