ArcGIS Pro Edit Button
743
04-01-2026 09:03 AM
GIS412
Hello,
We're on ArcGIS Pro 3.5.
Is there anyway to make the Edit button on at all times, and not allow the user to toggle it off? We're worried about users in our organization toggling the Edit button off and not having the extra layer of protection that Edit button and save/discard gives us.
JenniferCadkin
This option is available as an Administrator Setting.  To learn more, you can start here:  https://pro.arcgis.com/en/pro-app/latest/get-started/editing-settings.htm#GUID-D0D3C386-FBCB-4256-94...
Robert_LeClair
Esri Esteemed Contributor
So, question.  When you go to the Project->Options->Editing under the Session category, is the "Enable and disable editing from the Edit tab" checked on?  This is not the default setting.  The default setting is not have this checkbox enabled.  By doing that, editing is automatically enabled when a user clicks the Edit tab.  Save and discard options are still in play of course.
GIS412
Yes, I have this option toggled on. "Enable and disable editing form the Edit tab".
I want it so user's cannot toggle this setting off. It will always be on. Is it possible to do something like that?
JenniferCadkin
GIS412
This is exactly what I was looking for. Thank you!
