ArcGIS PRo does not show sde layers
1939
02-12-2021 09:38 AM
JoseSanchez
Hello everyone,
I am just starting using ArcGIS Pro, and after adding a layer from SDE, I can check that it has values on the attribute data, and zoom to layer also works, but  I do not see any shape drawn on the map.
Any idea what this happens?
Thanks
DanPatterson
MVP Esteemed Contributor
it is toggled on in the table of contents for the map?  and has a shape type field?
... sort of retired...
JoeBorgione
It may be that the visible scale is already set for the given layer and you aren't zoomed in enough to see any features. Take a look at the image below:
Notice in the table of contents the visibility check mark is grayed out for the layer Address Points.  Notice too that when I right click on Address Points and select properties, the properties window shows that I won't see any features until I am less than 1:10,000.  When I zoom to the extent of Address Points, I my map scale is at 1:275,623:
I can manually set that scale to 9,999 and everything switches 'on'....
I hope this helps...
That should just about do it....
