ArcGIS Pro, create mobile package failed
1259
04-02-2020 07:33 AM
YuyingLi
Hello,
I would like to create a mobile package for ArcGIS Explorer offline use. I published the host feature layer, added to ArcGIS pro, used Share --> create mobile map tool in Pro (2.5) to create mobile package...but kept failling. Any idea?
JonahLay
Hi Yuying Li,
What is the error you are seeing when sharing a mobile map package? Please refer to the following topic for more information: Share a mobile map package
Best,
Jonah
MervynLotter
MVP Regular Contributor
If you are consuming a hosted feature feature layer, then first make sure it is Sync enabled in AGOL.
Then have you used the Download Map functionality from the Map tab to first take the features offline before packaging?
