ArcGIS Pro: Create a polygon inside a polygon
1544
04-24-2020 05:43 AM
LiorHershkovitz
Hi
I have to cut a hole inside a polygon (I have to mark a tree segment in paving)
Which ArcGIS pro tool will to the job?
(attached a picture, I want to cut a rectangle  where the red mark is)
Thanks!
Lior
Tags (1)
George_Thompson
Esri Notable Contributor
If that red box is a polygon you can erase it with the following tool: Erase—Help | Documentation
Or you can do it interactively; Cut a hole in a polygon feature—ArcGIS Pro | Documentation
--- George T.
LiorHershkovitz
I'll try to do it!
by the way, is there an option to draw a polygon with specific measures?
