arcgis pro crashing
863
02-03-2022 03:40 AM
Hala_Ghareeb
Hi all,
Recently I upgraded ArcGIS Pro from 2.7 to 2.9, but I noticed that the software is not working as usual, and it crashes a lot suddenly.
Then I re-installed it again with version 2.7 and still crashes in the same way.
Tags (1)
DanPatterson
MVP Esteemed Contributor
from you uninstall/reinstall question
How To: Troubleshoot installation and uninstallation issues (esri.com)
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Related to your other post - "Once you uninstall ArcGIS Pro, I've found it useful to rename the ESRI folder in the C:\users\<user profile>\appdata\local and C:\users\<user profile>\appdata\roaming to ESRI_OLD before I do a clean install of ArcGIS Pro.  Seems to help the stranger issues seen..."
