ArcGIS Pro crashing constantly
13837
01-22-2022 11:28 AM
ChrisMacNeillNCFPD
Hey Everyone, I have been having a very tough time doing nearly anything in ArcGIS Pro the last couple days.  Even something as simple as turning a layer on and off, it just load and lags and then eventually it just crashes. This seemed to just happen out of the blue a couple days ago, wondering if anyone has any idea what the cause is, or if anyone has had a similar experience.
ChrisMacNeillNCFPD
Thanks Dan for the info.  I just went into another project and had no issues so it looks like its just that one specific project.
DanPatterson
MVP Esteemed Contributor
If it is with any project, including a new one, then something has happened to your install.
Windows, Add/Remove Programs, Remove then select Repair.
After a reboot, and if the problem persists, you may have to completely uninstall Pro and remove/rename any folders associated with esri, as well as registry data.  If you are uncomfortable doing that, then contact Tech Support
... sort of retired...
ChrisMacNeillNCFPD
TamsenWaldron
Me too
