Arcgis pro crashes when deleting a map from catalog
3373
8
04-13-2018 01:24 PM
NasirAhmad4
Whenever I try to delete a map from the catalog pane, ArcGIS Pro crashes even after removing all the layers. This happens on the first try on the second try it succeeds deleting the map.
Tags (1)
DanPatterson_Retired
Never seen that, which leave your profile and/or the location of your *.aprx and anything else you can provide about your environment
MichaelNau1
Just ran across this and it is happening every time I try to delete a data frame in the layout. EVERY TIME!!! No fix found yet.
Robert_LeClair
Esri Esteemed Contributor
What release of AGP are you using and do you have any Python scripts in the AGP project?
MichaelNau1
No Python scripts running. Pretty basic inset map in a data frame. Running Pro V. 2.3.0
KoryKramer
Esri Community Moderator
Michael - did you submit the error report and include a valid email address?  (See https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/arcgis-desktop-error-reporter-lea... for why this is very helpful).
I searched using your email and couldn't find a report, so I'm not sure what this crash is.  Could you please send the latest .dmp file from C:\Users\<username>\AppData\Local\ESRI\ErrorReports?
That way we'll be able to see if there might already be an existing fix in one of the patches for 2.3 or in the current version of ArcGIS Pro 2.4.
Thank you!
MichaelNau1
What is the best way to send the files to you? because I am on  Domain machine for the State of Idaho Military DIV either the error report fails to send or is under a different user name. I can send the .DMP files to you I think via email.DMP
MichaelNau1
Thank you for looking into this,
Here are a few. One of the DMP files is 18kb and wont attach for some reason.
Michael Nau
Michael.s.nau2.mil_IDARNG
KoryKramer
Thanks, Michael.
There are actually 2 unique crashes (unfortunately) indicated by those dmp files (3 of 1 and 1 separate crash).
What I can say after running these through our analyzer is that the unique crash is fixed in ArcGIS Pro 2.4.
While the other one is not showing a specific code fix, we actually don't have any other reports of it, meaning that it could be something specific to the data you're working with, the project, or the machine.  Not that we wouldn't be interested in understanding what is happening (because the application should never crash)...
But my best recommendation for now would be to upgrade to ArcGIS Pro 2.4 and see if the issue is resolved.
If not, it would be important to share specific steps that cause the crash so that we can try to reproduce and isolate the cause.
Thanks
