ArcGIS PRO crashes at start
4627
02-16-2016 01:59 AM
PanGIS
Hi guys,
I worked on PRO two weeks ago, last time. Everythings worked fine.
Today I tried to open it and it crashes while tries initializing.
I don't get any error message but the form to be sent to esri.
ArcGIS PRO 1.1
Any change has been made since last time.
Any suggestion?
Tags (1)
DanPatterson_Retired
Have you installed anything before things went bad?  Perhaps you may need to repair you installation
PanGIS
As i haven't installed anythingh recently, i didn't think to repair..
But, of course, it was the most obvious solution.
Thanks Dan.
PanGIS
A correction to my previous answer, I hope this can be helpfull to whom will face this issue in the next days.
It is true that ArcGIS PRO started after Dan's suggestion, but next day i had the same problem.
I didn't mention that I was working on W10 and I was aware of complatibility issues but the fact is that when I moved to W10, in December, PRO worked properly since then till one week ago. Then something happend.
Anyway, the definitive solution was moving to PRO 1.2.
