ArcGIS Pro Connection to PoatgreSQL issues
1269
11-27-2023 04:21 AM
JayneEvans
Hi, I'm trying to connect to a PostgreSQL database through ArcGIS Pro. I'm using a localhost version of Postgres while I test workflows. We have QGIS and ArcGIS users in the organisation and want them both to be able to access the same databases. I have ArcGIS Pro 3.1.0 and I have tried two different instances of PostgreSQL. PotsgreSQL 11 with PostGIS 3.3 and PostgreSQL 14 with PostGIS 3.2. With both I can setup the database connection and receive no error messages when connecting, but when I expand the database in the table of contents it appears empty despite there being tables in there. In QGIS the connection work perfectly.
Any tips would be appreciated.
George_Thompson
Esri Notable Contributor
Are you using the same connection information UN / PW in Pro as QGIS?
In my connections with PostgreSQL, I can see what the user has access to. If you have user with (superuser) then they can see many other items that some could not.
--- George T.
