arcgis pro can not add data
4245
09-28-2016 01:09 AM
Siva_Sankara_ReddyKallam
add data button grayed out, nor cant add any enterprise data, using a concurrent licnese
Robert_LeClair
Esri Notable Contributor
Interesting.  Are you following the workflow listed in the "Add data to a project" Help Topic?  https://pro.arcgis.com/en/pro-app/get-started/add-data-to-your-project.htm
JeremyWright
have you added a new map?  You can't add data until you have a map to put it in.
Also, try adding the data from the Project view right-click.  Does that work?
