ArcGIS Pro Calculator tool
1515
10-20-2021 10:07 AM
KateEkhator74
Hello,
Am trying to use  the calculate field tool in ArcGIS pro and I am not familiar with the python 3 if then statements and how to use the code block. Please can anyone help with some tips on how to  do this.
Thanks.
JayantaPoddar
Calculate Field Python examples—ArcGIS Pro | Documentation
You could use if, elif, else statements. e.g.
Expression:
Reclass(!WELL_YIELD!)
Code Block:
def Reclass(WellYield):
    if (WellYield >= 0 and WellYield <= 10):
        return 1
    elif (WellYield > 10 and WellYield <= 20):
        return 2
    elif (WellYield > 20 and WellYield <= 30):
        return 3
    elif (WellYield > 30):
        return 4
Think Location
KateEkhator74
Thank you.
jcarlson
You might also consider trying Arcade. Arcade translates across to the ArcGIS Online environment, popup expressions, etc., and is worth learning.
- Josh Carlson
Kendall County GIS
