ArcGIS Pro- Calculate Fields (Multiple) Respect Null Calculations
1662
7
06-13-2025 11:43 AM
Amanda__Huber
MVP Regular Contributor
Has anyone else seen issues when using the Calculate Fields (Multiple) tool, to calculate fields to NULL. I have tested using both Arcade and Python and the tool says it executes successful, but when viewing the data all the records are still there and are not NULL
Any insight into this would be appreciated.
Amanda Huber
RPGIS
by MVP Regular Contributor
Hi @Amanda__Huber,
Have you tried setting the expression to Null if arcade or None if python? Typically the expression should be set to one of these depending on the language you are using.
RPGIS
Hi @Amanda__Huber,
Robert_LeClair
Esri Esteemed Contributor
I tested RPGIS's suggestion with the expression being Null if arcade and None if python in ModelBuilder as you had in your graphic.  Works as expected.  Add Null or None to your expression parameter and it should work.
RPGIS
Hi @Amanda__Huber,
Were you able to get this resolved. I am simply checking because it has been a while and I just wanted to follow up.
Amanda__Huber
Apologies for the delay, yes we were able to!
RPGIS
Great. If it is alright with you I will go ahead and mark my response as the solution.
Amanda__Huber
Marked it!
RPGIS
Thanks Amanda.
