ArcGIS Pro Attribute Rules as Attribute Assistant Replacement?
8140
15
06-27-2018 11:53 AM
JoeBorgione
With the recent update of ArcGIS Pro to v 2.2, (see : What's new in ArcGIS Pro 2.2—ArcGIS Pro | ArcGIS Desktop ) there are two new tools for the 'Attribute Rules' tool set.  Truth be told, if I hadn't seen this I still wouldn't have known about them at all.
Two questions:
Are the Attribute Rule tools designed to replace the Attribute Assistant?
If that is the case, are there plans to incorporate their application to a fgdb?  ( I know: the ink isn't dry on 2.2 and I'm asking for improvements...)
Michael Miller
KoryKramer
Esri Esteemed Contributor
No worries, Josh.  I can't always help, but very happy to when I can.
Cheers
JoeBorgione
..occasionally obnoxious end users...
Wait...  Here on Geonet?  No way....
by Anonymous User
Not applicable
I was excited about Attribute Rules until I read this:
"Attribute rules are currently only supported on enterprise geodatabase datasets."
Every time I think about changing to Pro full time, something like this happens.
JoeBorgione
Yep... Well....
Hopefully there is strength in numbers; be sure to vote https://community.esri.com/ideas/15235
KoryKramer
JoeBorgione
Cool...  Still looking forward to:
Support attribute rules on file geodatabases – We will provide support for adding and executing immediate attribute rules (calculation and constraint) on file geodatabases.
