ArcGIS Pro: 3D cartesian coordinate system
3797
10-13-2020 05:21 AM
NicolasGIS
Honored Contributor
Hello Geodesists,
I am receiving data from custom 3D cartesian coordinate system I would like to define in ArcGIS Pro.
I computed the seven parameters to a 3D national system and there are equations to go from 3D cartesian to geographic that I believe ArcGIS Pro knows ?
It seems like I can define seven parameters method tranformation in ArcMap:
Equation-based methods—ArcMap | Documentation
But I can't find a way to define a coordinate system as 3D cartesian.
Did I miss anything ?
Thanks
DanPatterson
MVP Esteemed Contributor
Haven't tried it yet but
Specify a coordinate system—ArcGIS Pro | Documentation
shows how to define your own horizonal and vertical coordinate systems...
... sort of retired...
NicolasGIS
Honored Contributor
Thanks for your reply.
That is not exactly what I am looking for. I am looking for X, Y, Z 3D coordinate (without ellipsoid definition).
Then you can directly compute lat, lon, and H when an ellipsoid is defined and easily work with well-known geodesic datum.
Maybe Melita Kennedy‌ will have an idea ?
MelitaKennedy
Esri Notable Contributor
We don't support 3D Cartesian in ArcGIS yet. It is in the Esri projection engine, but not exposed in the software using the library. I'm sorry!
Melita
NicolasGIS
Honored Contributor
I am not sure to understand: can it be somehow extended using Esri projection engine ?
Thanks !
NicolasGIS
Honored Contributor
Hello @MelitaKennedy,
Just wanted to tell that it is disappointing that it is not available in the softwares as it would be really helpful to manipulate CAD and BIM data using generally a random 3D coordinate system.
Is it something planned or not at all ?
Thank
