After I updated to 3.4, I've been getting frequent crashes when opening an existing project file for an operation, I'm not sure which operation is causing the crash, but the operation before each crash is different. It has crashed three times in the last hour and I have sent reports for all of them. Does anyone know of a potential cause of the crashes for me to avoid?
Solved! Go to Solution.
Joined the forums just to one up this, has plagued me with work and school projects since upgrading. Exporting layouts and changing symbology seem to be the worst culprits for me. Also random crashes with multiple layouts and maps open at once
I'm also experiencing frequent crashes with 3.4, and it usually occurs with editing polygon vertices. I've tried a clean install, a soft reset, frequent cache clearing, but the problem persists.
The crashing in combination with the slow project start-up (takes around 5 minutes to launch a project) that has plagued me since around version 3.3, makes me almost want to revert to version 3.2. I'm still holding out hope that the next patch will fix the problem.
I refuse to reach out to support because I've been down that painful road before.
I've been noticing regular crashes with 3.4 when doing the most basic of edits - edit vertices. I tried turning on auto save to avoid losing work but that didn't work. I just lost about an hours worth of work to yet another crash. I think its happened four times already today
Really slow performance (more than usual!) with version 3.4 since I updated as well. Don't really get crashes as such just seems to hang constantly doing most things. Thank goodness I've still got version 3.3 on our main GIS workhorse machine!!
My projects haven't crashed, but my attribute tables constantly freeze up after calculating geometry (on only one feature). I have to close the table and reopen. I've tried closing the project and reopening, but the issue still occurs. Will be passing this onto our Esri rep, too.
Using Pro 3.4 here. Have slow startup of new projects, select by attribute from small polygon set is slow (10-15 min), repeated crashes. Any geoprocessing tasks either crash or take forever to complete.
I'm still running 3.3.x and everything is fine. Has anyone updated to 3.4.1 or 2? Did things smooth out as in can I update now, or still hold back?
I have had issued with crashes when trying to add new bookmarks, and some of my old bookmarks are now blank and I can't remove them.
Has SP 1 or SP 3 for ArcGIS Pro 3.4 resolved these errors?
