ArcGIS Pro 3.4.0 Visualization Issues-- Bug?
2416
23
11-25-2024 11:31 AM
KCI
I'm having an issue in 3.4.0 where ArcPro is creating weird artifacts in multiple unique Projects. Take a look:
The 2nd image shows that it's creating these artifacts around the basemap as well-- not just the features I'm using.
This issue doesn't exist outside of ArcPro, leading me to think it's not a PC issue, such as a bad graphics card.
No idea what's happening, preventing me from asking intelligent questions.
Thanks for your help!
JeremyWright
Hi, we've seen this visual artifact in the past with older drivers, especially with Intel GPUs, when using DirectX 12.  We confirmed with Intel that later versions of the drivers fixed the artifacts.
Please let us know what is listed under \display adapters in Device manager and what date/version the driver shows in its properties.
To try and work around it, switch to DirectX 11 or OpenGL in Pro's options->display tab.
WillardGustafson_FNI
I'm having this same issue, Random color blocks that cover whole sections of my maps, with "holes" where labels are.
JeremyWright
JeremyWright
Hi everyone - if switching to DirectX11 worked (as someone has marked this as "resolved") please let us know your display adaptor's model name and driver version shown in device manager.  If needed we can contact the GPU manufacturer to report it as a bug (if updating the driver version doesn't fix it for you).
KCI
I switched to OpenGL and my problems went away!
JeremyWright
@KCI Can you please go and tell us what shows up in device manager under Display Adaptors an open it and give us driver version and date?
KCI
JeremyWright
OK yep, I have same GPU in my daily driver laptop.  After we reported the issue to Intel, I had updated to september driver version and the problem went away.  Both Dell Support and the Intel Driver Support Assistant showed me the updated drivers, so you should just be able to tell your support department to update to the latest driver to resolve the problem.
Minsley
I have the same display Driver
This is the most up-to-date Driver available for my laptop.... Are ESRI telling us to opt for a retro Drisver?
MariusVerdes
I also had the same problem with ArcGIS Pro 3.4; the issue was the Intel Graphics driver. In the Device Manager, under Display adapters I tried to update the driver but Windows didn't find anything newer than what I initially had. I downloaded the Intel Driver Support Assistant as Jeremy suggested above and updated all my Intel drivers, including the display adapter. After that and a restart, everything works great with DirectX 12.
