ArcGIS Pro 3.3 performance
17863
36
05-15-2024 09:30 AM
HollyTorpey_LSA
Is anyone else noticing any performance issues in Pro 3.3? We are, but I'm trying to figure out if it's a Pro update issue or something in our network/system configuration (or a combination of the two). Would especially love to hear from others who have updated to Pro 3.3 on a multi-session virtual desktop where users use Pro to work with data stored on cloud-based fileshares.
Thanks in advance!
- Holly
SangHyouk_Oum
We have a similar experience to share. I have a script that performs memory-intensive tasks using ArcPy, which has been running for years with both ArcGIS Desktop and Pro. Normally, the script takes about 3 days to complete. However, after upgrading to ArcGIS Pro 3.3 recently, the same script now takes more than 2 weeks to finish. After downgrading to version 3.0.6, the speed returned to "normal."
KyleLandon
I am also getting a lot of CShareQueue timeouts in the log. ArcGIS Pro is just taking forever to render even simple maps or apply symbology changes. I'm using a high performance virtual machine and am on 3.3.1.
EDIT: I noticed there was a 3.3.2 update and I installed it. I also set ArcGIS Pro to clear Cache on exit and to use DirectX 12. It seems way better now.
AllenovDmitriy
I'm not using any clouds, but ArcGIS Pro 3.1 works perfectly compared to the horror of the 3.3 update. It has become impossible to work with new patches.
TomDe_Leus
3.3 is terribly slow, some times OK, but then suddenly adding a layer whatever takes very long,  bcomes impossible to work ...
ReamonnMFealy
Just to add that our experience is very similar to all that described by others above. For what its worth CSharedQueue Stall timeout is also a strong feature in our Diagnostic Monitor logs...
mdumas_SILC
Anyone every find a solution for this? I've been experiencing this for months on a variety of machines.
Michael_Kraus
We are also getting lots of CSharedQueue Stall timeout errors - very impactful and detrimental to performance.  Running 3.3.2
AyanPalit
Recommend reviewing the following resources:
Troubleshooting Performance Issues in ArcGIS Pro
Diagnostic Monitor
Performance Assessment Tool
Ayan Palit | Principal Consultant Esri
jorisfrenkel
Ouch, this sounds really bad.
Any updates on this? Is 3.3.5 an improvement?
We are planning to upgrade from 3.1 to 3.3, because an essential Add-In we use is not working on 3.4.
- Joris
DavidLight
Pro 3.3 is very slow for us as well.  Any resolutions?
