ArcGIS Pro 3.3.2 Attribute Tables Gray Out
6160
16
10-01-2024 12:09 PM
DonnaMoreau
Hello,
This issue appeared in version 3.3.1 also, but it seems to happen more frequently in version 3.3.2.
Scenario:
I selected multiple rows of data in a feature class called Wastewater Gravity Mains. I zoomed in and out of the map a couple of times, then switched the Attribute Table (not window) view to Selected records. It's like the table froze, and icons at the bottom of the table grayed out so that they could not be selected. Sometimes, the records in the table even empty out completely, even though they are still selected in the map.
My solution has been to close out of the Pro session, and when I open it again, everything is fine. However, sometimes that does not work, and then I have to remove the table completely and readd it.
Is there something I am doing incorrectly or could this be a bug in the system?
Thank you,
Donna
RichardDaniels
MVP Regular Contributor
ESRI just released SP 6 for ArcGIS Pro 3.3, it has several bug fixes related to 'ArcGIS Pro grays out when...'. Recommend you give it a try.
zhuzhu
I'm on 3.3.6 and the attribute table still grey out.
jorisfrenkel
Good to know, we're on 3.3.5 and having this problem too.
RichardDaniels
You should load Service Pack 6 for ArcGIS Pro 3.3 and solve this problem.
jorisfrenkel
Thanks, but I just read someone saying the problem is still there in 3.3.6
jorisfrenkel
Debert
Unfortunately, I'm experiencing this issue in ArcGIS Pro 3.5.3. I've been troubleshooting attribute table issues with Support for over 5 months and seems like a major waste of time. They've had me try everything under the sun with zero accountability on their end. It has been very frustrating and time consuming with no resolve.
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
