ArcGIS Pro 3.2 database connections to SQL Server 2019 not showing contents, no error
16307
12
11-22-2023 08:48 AM
Jamie_Leitch_CNF
I just upgraded to ArcGIS Pro 3.2 on Windows 10 machine.  When I right-click and Refresh any existing database connections, nothing happens.  I cannot see the contents of the database at all and there are no errors.  I can create a new feature class successfully.  I tried creating a new database connection and it is created successfully but I cannot open the connection to see the contents, refresh does nothing.  I've installed the MS ODBC Driver 18 for SQL Server.  Existing projects created in 3.1 that have feature classes from the same database connections load and show up in the map and can view and edit records in the attribute table.
Geodatabase version: 11.0.0.3.0
SQL Server Version: 2019
Any ideas?
SGTomlins
I only turned off indexing as suggested.  It solved the problem.  🙂
Jamie_Leitch_CNF
@JonM32 thanks for this info, I will be trying this.  I've found that this issue most often occurs with aprx files that had been created prior to upgrading to 3.2, not sure if that's significant or not.
ctalleygreenville
This solved our problem as well.
One user could no longer connect to the enterprise geodatabase.  It was sudden and only affected this one user.  It turns out that she had enabled the Pro Options-->Indexing-->Create and manage your own index-->index items about a month ago.
We deleted all the folders in this directory on her computer as mentioned above: C:\Users\<user name>\AppData\Local\ESRI\Index\
Then "un-enabled" the index items option.
Her enterprise geodatabase connections worked immediately.
