ArcGIS Pro 3.1 - issues with publishing certain hosted feature layers
637
03-21-2023 06:35 AM
DavidColey
MVP Frequent Contributor
Hello - has anyone encountered any issues with publishing certain hosted feature layers from ArcGIS Pro 3.1 to ArcEnterprise 11.0?
Typically I right-click a layer in the TOC, select 'share as web layer', set parameters as:
No editing
Summary
Add tags
Time zone EST
Adjust for Daylight Savings
No assignment of unique ids - I want each layer to post at index 0 for access in open data
That's it.  Very simple.  Been using this method since Pro 1.x.  Now everything just hangs on the Upload Service Definition stage.
Interestingly, the arcpy method for sharing: stageSDDraft>StageService>UploadServiceDefinition from my python IDLE works just fine.
This made me think that my Pro staging directory was somehow inaccessible to the hosting server, but I push vector tile packages from that location via python all the time and it still works.
David
