ArcGIS Pro (3.1.3) - Features to GPX
676
10-23-2023 02:20 PM
MichaelPillers
I am attempting to generate some .gpx files (tracks) from some simple line features (with z values).  The process runs successfully.  The output files, however, contain three copies of each trackpoint.  This is causing a problem in the application that uses the .gpx files.
SeaRM
Hello, Michael.
I can suggest you trying to use XTools Pro Export to GPX tool. You can export lines and polygons to GPX routes or tracks.
MichaelPillers
Thanks.  I'm not using XTools so will continue to investigate cause, perhaps modifying tool coding.
