ArcGIS Pro 3.0 "Failed to create notebook server" after installing additional Python package
3042
07-13-2022 07:26 AM
ReinhardtBotha
Has anyone been able to install additional python packages for their cloned Python Environment in ArcGIS Pro 3.0 succesfully? I have been struggling to install the cartopy package.
Using the Package Manager, if I initially search for cartopy it finds nothing.
So I used conda in the Python Command prompt to install it with:
conda install -c conda-forge cartopy
Doing this successfully installs the package and it also shows up in my Package Manager afterwards:
However, now when I open any notebook, or try to create a new one I get the "Failed to create notebook server" error:
Any suggestions will be appreciated!
DanPatterson
MVP Esteemed Contributor
When you conda installed, did any other packages get added?, changed?
I would do
conda list --revisions
then if you want to roll back to a prior state
conda install --revision X
where X is the number of the state where all was good
... sort of retired...
ReinhardtBotha
Other packages got added and some were changed yes. The latest revision was revision 2, where I can see the cartopy packages were added. I rolled back to revision 0 and still get the same error when I try to open a notebook now. Wonder what is causing this.
Update: When switching back to the default Python environment, the notebooks work fine again. So seems like something happens to the cloned environment after the conda install.
DanPatterson
Delete the clone, reclone, install cartopy first, try it out, and if it works then it is the other packages that may be causing the issue with cartopy.  Incrementally add the additional packages to see if you can narrow down the problem.
Also, record and changes conda may want to make when you install cartopy or use
>>> conda install cartopy --dry-run
to get a pre-test of the installs desires and note them here if you problem isn't resolved
ShaunWalbridge
For earlier Pro releases, we had made a custom build of cartopy and put that up into our Esri channel, but hadn't done that work for Pro 3.0. Because of its use of a number of packages which overlap with the core distribution of Pro, it may be challenging to get a solid build without some work on our end, but I would start with this:
Run a clone from the UI or with `conda create --clone arcgispro-py3 --name cartopy --pinned`. The `--pinned` here is important because that will constrain the package set for things like Notebooks to the versions we use in Pro. In this created environment after activating, try just running `conda install cartopy`. If that doesn't solve, it means that some of the packages Pro requires aren't compatible with the build up on Anaconda. As a short-term fix you may want to make a separate environment without ArcPy and install cartopy into that, but obviously that's not ideal.
Cheers, Shaun
ReinhardtBotha
Thank you for the reply and information @ShaunWalbridge, I'll have a look at this again at a later stage and post my findings.
