ArcGIS pro 3.0 Append
6144
13
06-30-2022 02:12 PM
RyanTucker
For some reason Append in the latest update, 3.0,  is no longer letting me remove fields. Nor is it allowing me to set the globalID as type GUID. Anyone else having this issue?
RyanTucker
ESRI Closed the bug. They claim this is how it is supposed to work.  Even though prior to version 3.0 it worked the opposite way.
I escalated:
Business Justification: Then you guys need to explain HOW are we to maintain globalID's from existing datasets if we want to load the existing data into a new schema? Merge tool doesnt work for that.
No. of people affected: 1
I received no answer or explanation as to how to achieve the end goal. Typical as of late.
JosephHilliard94
Thanks for keeping us updated, frustrating, may have to stick with 2.9 for now! Definitely not as designed if they have removed a workaround for a bug!
RyanTucker
@JosephHilliard94
We have a workaround! Someone dropped the workaround on another of my threads:
 https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-3-0-globalid-fields-not-indexed-as/m-p...
Use mobile database to append the data then convert to File geodatabase. Not pretty , but it works
JosephHilliard94
Thank you for letting me know, super helpful!
