ArcGIS Pro 3.0.2: How to remove a particular layer from the legend but still having it turned it on (visible) on the map?
7087
12-16-2023 11:57 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, I wanted to remove the JifnaParcels from the legend but still having it visible on the map.
How this might be performed?
Jamal Numan
RonaldHaug
Hi Jamal,
Uncheck the box for JifnaParcels under the legend.
Only checked items will appear on the legend.
DanPatterson
MVP Esteemed Contributor
Arrange a legend—ArcGIS Pro | Documentation
convert the legend to graphics and then delete what you want
However... the legend and the table of contents for the map will not syncronize then, so do this when you have the map the way you want it, as your last step for the layout
... sort of retired...
CQuick
Hi Jamal,
I would right click on the JifnaParcels layer in the legend and click 'Remove'. This allows the layer to still show in the map (if it is on in Contents), but not be shown in the legend.
Original map:
Turning off the legend layer:
Final map showing all the layers, but only two in the legend:
RonaldHaug
Hi Jamal,
JamalNUMAN
Many thanks for the help
Jamal Numan
