ArcGIS Pro 3.0.1: How to run a python script by Windows “task scheduler”?
9951
13
08-31-2022 01:51 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, I wanted to run a python script that performs the buffer for a given feature class. I fill the “buffer.py” script in the “add argument” box but couldn’t figure out what to stick in the “Program/scrip” box
Jamal Numan
RichardHowe
The script (.py file) goes in the "program/script" box. You don't need any arguments!
MichaelVolz
Esteemed Contributor
Did you ever do this with ArcMap based python scripts?  If so, the only difference should be the path to python for ArcGIS Pro.
JamalNUMAN
It appears that sticking the python file in the "program/script" box doesn’t generate the expected feature class in the destination geodatabase (C:\Z7\Q.gdb)
What could be the issue here?
Jamal Numan
RichardHowe
Try copying and pasting the following into notepad:
"c:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe" "c:\Z7\Buffer.py"
And saving with a .bat extension. Then pointing task scheduler to that
JamalNUMAN
The .bat file appears not to work as per the screenshots below
Jamal Numan
MichaelVolz
Can you provide a screenshot of your bat file code?
JamalNUMAN
Sure. Here you go
Jamal Numan
RhettZufelt
MVP Notable Contributor
I don't see anywhere that creates the C:\\Z7\\Q.gdb\\L1 feature class?
I see where you try to use it as an input feature class, but by the lack of arrow next to the Q.gdb, that would suggest the FGDB is empty (is there an existing L1 feature class in the Q.gdb?).
If not, the buffer tool can't use a non-existent dataset as an input.
R_
JamalNUMAN
All what I wanted here is to run the buffer tool by windows task scheduler. The python script is extracted from the model. It runs successfully thought the Pro as per the screenshots below.
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2022-08-31 11:41:53
import arcpy
def Model():  # Buffer
    # To allow overwriting outputs change overwriteOutput option to True.
    arcpy.env.overwriteOutput = True
    # Model Environment settings
    with arcpy.EnvManager(scratchWorkspace=r"C:\Z7\Q.gdb"):
        L1 = "L1"
        # Process: Buffer (Buffer) (analysis)
        L1_Buffer = "C:\\Z7\\Q.gdb\\L1_Buffer"
        arcpy.analysis.Buffer(in_features=L1, out_feature_class=L1_Buffer, buffer_distance_or_field="5 Meters", line_side="FULL", line_end_type="ROUND", dissolve_option="NONE", dissolve_field=[], method="PLANAR")
if __name__ == '__main__':
    # Global Environment settings
    with arcpy.EnvManager(workspace=r"C:\Users\jamal2\AppData\Local\Temp\ArcGISProTemp13328\3aee01c4-83fc-49dc-a1a9-1160767de7fc\Default.gdb"):
        Model()
Why the script fails to run from the windows task scheduler?
Jamal Numan
