ArcGIS Pro 2.9: How to split lines at intersection within a model builder?
I couldn’t figure out if there is a model builder tool that can split lines at intersection
Solved! Go to Solution.
Feature Vertices To Points (Data Management)—ArcGIS Pro | Documentation
then
Split Line at Point (Data Management)—ArcGIS Pro | Documentation
But your lines should meet
Else
Intersect (Analysis)—ArcGIS Pro | Documentation (Only single input layer. Output Type: Point)
followed by
You should need only one tool, Feature To Line. 🙂
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/feature-to-line.htm
then
Else
followed by
it works fine. Thank you
Correct. It works fine with one tool “feature to line” as per the screenshots below
