ArcGIS Pro 2.9: How to split lines at intersection within a model builder?
3013
12-31-2021 03:06 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is a model builder tool that can split lines at intersection
Jamal Numan
3 Solutions
JayantaPoddar
DanLee
by Esri Regular Contributor
DanPatterson
MVP Esteemed Contributor
JayantaPoddar
Else
Intersect (Analysis)—ArcGIS Pro | Documentation (Only single input layer. Output Type: Point)
followed by
Split Line at Point (Data Management)—ArcGIS Pro | Documentation
Think Location
JamalNUMAN
it works fine. Thank you
Jamal Numan
DanLee
JamalNUMAN
Correct. It works fine with one tool “feature to line” as per the screenshots below
Jamal Numan
