ArcGIS Pro 2.8 crashed when changing Symbology
1189
11-04-2025 04:52 AM
TonyDao
Hi everyone,
Could anyone please help me fix an issue I’m having when changing the symbology in ArcGIS Pro 2.8 (the client requires the project to remain in version 2.8)?
From what I’ve read, installing patch 2.8.8 might resolve this issue. However, I couldn’t find the patch in My Esri.
Any help or guidance would be greatly appreciated.
Thank you in advance!
George_Thompson
Esri Notable Contributor
I would like to note that Pro 2.8.x was retired about 18 months ago (June 1, 2024 - https://support.esri.com/en-us/products/arcgis-pro/life-cycle).
I would recommend that you upgrade to a more recent version of Pro, which is supported. Pro 3.1.x is the "oldest" supported version.
Is there a reason that you still on Pro 2.8.x?
--- George T.
TonyDao
Hi George,
Thanks for your reply. As I mentioned in the previous email, the client of mine insisted it to be 2.8 version.
Upgrading from 2.8 to 3.1.x , is it free of charge?
So, there is no way we can fix the issue?
George_Thompson
The client (you) should be able to upgrade to 3.1.x, if you are current on the software maintenance. You could get an updated license file and move to 3.1.x or newer.
I am not aware of any public location to download that patch, since the software is retired.
--- George T.
EdMorris
Hey Tony
I bet the answer is down to a display driver problem. I had this issue many moons ago and I found that my laptop was using the "standard" Windows display drivers and not the recommended graphics card display drivers. I think you will be fine when you update the drivers to the graphics card drivers.
Let us know how you get on as it all adds to the knowledge base.
many thanks ed
RhettZufelt
MVP Notable Contributor
I used to have that issue back when running 2.x versions.
It was related to Microsoft KB updates.  Every time the system 'updated', I had to remove the updates from the computer to be able to change/modify the symbology without it crashing (which is a never ending cycle, and probably not the best for security).
Believe 3.1 is when that issue was resolved if I remember correctly, but it's been a while.
R_
