After I upgraded from Pro 2.7 to 2.8.1 I can't connect anymore to network drives!!
Our network goes over few VLANs. I figured that when I try to connect to a network drive that on the same VLAN as my computer - there is no problem. But, when I try to connect to a drive that on a different VLAN I get this error: "Cannot access B:\" (B is one of my network drives letter). It doesn't matter if i try to connect with the full network path (not the drive letter).
Before upgrading to Pro 2.8 on Pro 2.6 and 2.7 there wasn't any problem to connect to these Network Drives.
Any ideas how to solve this?
Daniel
Solved! Go to Solution.
Hi there,
Thank you very much - I'll try your solution.
I also found a workaround: If I drag with the mouse the folder or Drive letter from the file explorer to the Catalog view - it works ( Go figure 🤷:male_sign:).
Hi DrVSSKiran,
Your solution doesn't work on our computers.
However I found a workaround solution: If I drag a folder or network path with the mouse (or the the Drive letter) from the file explorer to the Catalog view - it works ( Go figure 🤷).
Disconnect your network drive from your system and restart it. After restarting the system try to reconfigure the network drive and assign the B: drive and try once. Hope the problem will resolve. Some time external drive and network drive will create an issue if any temp files are blocked.
Hi DrVSSKiran,
Great.
I think this happens when you try to connect to a network drive that is on a different VLAN.
Hi there,
it worked for me! thanks
Drag folder and drop worked! Thanks!
